I just bought a broken 34461A. When I power it on, it reaches the Windows CE splash screen (see attached image) and then freezes. I’ve connected it to my network—my router reports a 100 Mbps link, the Ethernet LED is blinking—but the meter never obtains an IP address. On the serial console I see:
U-Boot 2010.03 (Oct 09 2012 - 12:48:30) Agilent P510
CPU: SPEAr320
DRAM: 128 MiB
Unknown id: 0xffffff. Using ST_M23P40
Flash: 64 KiB
NAND: INTERNAL ECC 128 MiB
In: serial
Out: serial
Err: serial
SerNum: MY99999999
Chip: AA Board Rev: 4
init RTC: 2001-01-02 20:25:48.30
Net: Phy could not be configured
No ethernet found.
splash RTC: 2001-01-02 20:25:48.46
Press spa...
NAND read: device 0 offset 0x320000, size 0x10000
65536 bytes read: OK
## Booting kernel from Legacy Image at 00600000 …
XXXXXXOXrom_offset=0x0.
XXImageStart = 0x80361000, ImageLength = 0x16595AC, LaunchAddr = 0x80362000
Completed file(s):
- : Address=0x80361000 Length=0x16595AC Name="" Target=RAM
Loading image 1 succeeded.
ROMHDR at Address 80361044h
Preparing launch...
No RTC on 320
Launching windows CE image by jumping...
ERROR: C:\WINCE600\PLATFORM\COMMON\SRC\SOC\STM\SPEARHEAD600\DRIVERS\NandFlash\.\sh600_NandFlash.c line 57: ConfigTimming - Unable to open device registry entry
ERROR: C:\WINCE600\PLATFORM\COMMON\SRC\SOC\STM\COMMON\DRIVERS\NandFlash\.\stm_NandFlash.c line 1043: LLD_GetInfo - Unable to open device registry entry
++SER_Init: context Drivers\Active\10
SER_Init, dwIndex:2
GPIO_Select0 Register 0xB3...
OHCI\system.c, GCFG_USBH1_SW_RST
OHCI\system.c, GCFG_USBH2_SW_RST
SER_Init, dwIndex:2
also for log I can only read the log I cant input anything because it use logic analyzer.what tools do you recommend for interacting with the 34461A’s console?
and I not that good with English if there any miss understanding I feel very sorry for that
