I wonder, why is it useless for you though? The frequency changes as requested. It's just that while it's going through steps, it blanks out the output to NOT put uncertainty in the signal. Since PLL, by nature, is step-by-step method, if they didn't blank it out, it could be anything out there.
Many years ago, I have designed a primitive (by today's standard) PLL signal generator. Literally, when I change the frequency, the input to charge pump does up, down, up, down,until it settles down. It will go outside of before, and after, frequency. I think some people call it "ringing".
I always thought option 105 is to enable/disable the OUTPUT button. I've never tried though.
