Author Topic: I have repaired a Keithley 610C Electrometer and made a video  (Read 4187 times)
Offline baltersiceTopic starter
« on: December 05, 2016, 02:37:02 pm »
The fault was extremely simple in the end, not even worth a video.
But the footage was too good for the trash, so this came out:
I got that meter for roughly 30$ from eBay, perfect condition but non-functional.
The first thing I checked was the discrete amplifier module, where a diode had shorted.
The following users thanked this post: chickenHeadKnob, Macbeth, 005
Offline HighVoltage
Re: I have repaired a Keithley 610C Electrometer and made a video
« Reply #1 on: December 05, 2016, 08:12:13 pm »
Very nice presentation of this repair.
Thank you for sharing.
Offline dacman
« Reply #2 on: December 06, 2016, 12:12:23 am »
Nice video.  Something I noticed was the rear output switch was set to 1 MA.  The 1 MA / 3 V switch on the back is supposed to be set to 3 V if the output isn't connected to a 1 MA recorder.  There is a note about this in section 2-1 of the 610C manual.
Offline The_Penguin
« Reply #3 on: December 06, 2016, 12:26:34 am »
Awesome video. The intro was almost pornographic.
The build quality, and looks as clean as the day it was made. Wow.
« Last Edit: December 06, 2016, 12:28:43 am by The_Penguin »
Online Vgkid
« Reply #4 on: December 06, 2016, 04:13:25 am »
Nice job on the fix. Always wanted an electronometer to mess around with, but wouldn't have much use for it.
Offline Johnny10
« Reply #5 on: December 06, 2016, 03:12:56 pm »
Liked your video.
I bought a Keithley Model 210 Vacuum Tube Electrometer this summer at a yard sale.
Needs a lot of work and I believe a few almost unavailable accessories to operate properly.
Hope to get to this early next year.
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Offline Cyberdragon
« Reply #6 on: December 06, 2016, 06:54:17 pm »
What accessories? It's just a special voltmeter isn't it? If it needs some sort of attenuated probes you could probably just make some.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline quarks
« Reply #7 on: December 06, 2016, 07:05:44 pm »
very nice :-+
Offline Johnny10
« Reply #8 on: December 06, 2016, 08:50:43 pm »
Accessories to make it more complete; Ohms, Amps, High Voltage
Offline lowimpedance
  • Watts in an ohm?
« Reply #9 on: December 07, 2016, 01:21:46 am »
That is indeed an oldie, :), whats the odds of ever finding any of those accessories I wonder !.
Good luck with the restoration.
Offline VintageNut
« Reply #10 on: December 10, 2016, 03:44:17 pm »
There is a shunt for the model 200 on eBay. Not sure if this is a drop in for the model 210.
http://www.ebay.com/itm/Keithley-2001-ElectroMeter-Shunt-for-200-Vacuum-Tube-Electrometer-Priority-SH-/232162654709?hash=item360df8f9f5:g:kzIAAOSwl9BWK3~3
You applications posting is very cool. I have an original model 210 paper manual. The manual was produced in September 1957.
working instruments :Keithley 260,261,2750,7708, 2000 (calibrated), 2015, 236, 237, 238, 147, 220,  Rigol DG1032  PAR Model 128 Lock-In amplifier, Fluke 332A, Gen Res 4107 KVD, 4107D KVD, Fluke 731B X2 (calibrated), Fluke 5450A (calibrated)
The following users thanked this post: Johnny10
Offline schopi68
    • My stuff page
« Reply #11 on: December 30, 2016, 02:54:34 pm »
Just to metion: replacing the transistor in diode configuration with an standard diode does not complete the repair work.
A diode-connected transistor has a very low reverse leakage current (what is an important aspect in applications with high input impedance).  ;)
