Author Topic: Identifying Belt Specs for Cassette Players?  (Read 6111 times)
Offline cmirocTopic starter
« on: February 08, 2024, 01:20:22 am »
Does anyone know either:
(1) an extensive resource for finding specs for a replacement belt in a specific audio cassette device
OR
(2) how to find the right belt without resorting to trial and error?
I’m specifically looking to repair a General Electric 3-5300B “Compact Cassette Recorder.” Although it seems common, it’s not a deck I can find a matching belt for using my usual sources (webspareparts or fixyouraudio).
Offline amyk
Re: Identifying Belt Specs for Cassette Players?
« Reply #1 on: February 08, 2024, 01:34:14 am »
Measure circumference with string and subtract a few % for stretch.
The following users thanked this post: cmiroc
Offline fzabkar
« Reply #2 on: February 08, 2024, 02:22:44 am »
Cut the old belt in half and measure its length. Take note of the thickness and cross-section.
Online CaptDon
  • Country: is
« Reply #3 on: February 08, 2024, 04:10:47 am »
You need to generate the specs then order accordingly. If round belt measure diameter and length. If square belt get dimension of square and length. If flat belt get width, thickness and length. To get accurate length you will destroy the old belt by cutting it and then measuring and then subtracting a certain percentage to compensate for the stretch that occurred over time. The get on a belt website and find the closest match. The place I use sells phonograph parts mainly but has also every belt I ever needed.
