such meter from the JDSU actually is from Gencomm of Korea, so the RF circuit is quite fair, the performance may not so good (speed and dynamic range etc), also I found some flash eprom corrupt problem, for your case, just check which chip include the data you need, copy from a normal meter is OK.
