Hi All,
I recently repaired a K2001 which solved a problem with it, a video will be published in the next month or so.
However when I went to do the calibration I am getting an Error 354 during the resistance calibration stages, which is supposed to be a "200mV offset" out of tolerance or something.
I have not dug into this too deeply yet, but thought I would ask if anyone else has come across this and found a cause for it, or can even give me a tip about where to look, as there are multiple 200mV offsets mentioned in the manual for different things.
