Well, no, if that issue is what's causing the fail. I dunno WTF is causing the fails though, so... 🤷
Reading the other threads, and even checking the numbers I referenced, it didn't take much for the tests to fail. For that member, replacing the TF-245 resolved his meter's fails.
Besides that, accuracy should be able to be adjusted during a calibration. At that point, stability would maintain the accuracy, no?
