To rule it out, I replaced U176. The problem in the 10V range persists. Not surprising.
Anyway, it's probably worse now.
Before it would go to -11.9V in the 10V range stay there. Now it goes out of range. Of course, the problem only seems to exist in the 10V range, so switching ranges isn't helpful. Never mind. It's stopping at -11.9V again after warming up for a bit.
I suppose this verifies that I need to chase down some stupid switches.
Is there an simple way to test Q104, Q105, Q108, and Q113?
Does anybody know the correct replacement part numbers for them? The manual says SNJ132199. ETA: maybe MMBF4393LT1G?
One other question- is it possible I'm not cleaning the board well enough, and that's responsible for the leakage?
Thanks,
Josh
