Hey all,
I just grabbed one of these units off eBay, advertised as “used, powers up, as-is.” I asked the seller whether it actually worked and he said that it does and was pulled from a working environment, but some time ago.
Needless to say, when I got the unit it was exhibiting a problem from the start (pun intended). Namely that initially when I pressed the power switch, about half the time it would start up without issue, passing self tests and getting to standby mode. The other half of the time the fan would come on (I understand this is a 115V AC fan on its own transformer tap?) but the display would remain blank. No errors, no other indicators, just remained blank. I have not opened the unit yet because I want to be sure I’m going to hang on to it, but it feels like a mechanical issue rather than an electrical issue because lifting an edge of the unit about a centimeter and setting it down firmly resolves the issue sometimes, but usually only for 1 startup. At this point it almost never powers up without some jostling as described above.
Once started the unit seems to check out based on the limited testing I have done. it sources voltage fairly accurately on all ranges, including the resonant converter, right up to the limit. It also seems to source current accurately through the full range of compliance voltages as well. It may or may not be within calibration limits but if it isn’t it’s very close.
So my question is, has anyone experienced a similar issues with one of these units? Does anyone know if there are common issues of this sort with these units. Yes, I will crack it open at some point and have a look but if anyone has a clue about what this might be before that, it would make my decision easier.
In case anyone is wondering why I’m hesitant to just crack it open it is because the seller added some tamper resistant tape to the case between the time it was photographed and when I received it. Presumably this was to protect himself against scammers who buy stuff and remove parts?? In any case if I decide it’s not worth my trouble I don’t want to complicate things by being accused of trying to scam him.
