Here is the datasheet for the PCF7x41 single-chip solution:
PCF7x41ATJ, NXP, Security Transponder and RISC Controller (STARC 2XLite):
https://media.digikey.com/pdf/Data%20Sheets/NXP%20PDFs/PCF7x41ATJ.pdfPage 10 talks about the EEPROM content at delivery.
Bit 7 to 4 of this page (Identifier) serve the function of a product type (application) identifier and are set to ‘0110’ for the PCF7x41ATJ. For system compatibility reasons, the same product type Identifier is used by PCF7x21 (KEECOR).
AISI, the PCF7x21 chips are the predecessors of the PCF7x41 and are part of a 2-chip solution.
Page 4 of the same datasheet explains the part number coding.
PCF7941ATJ/CA1B00E0 represents the E-ROM product for development and applications with low quantities.
PCF7941ATJ/CA1Brrff represents a customized E-ROM product.
PCF7341ATJ/C0ABrrff represents the ROM coded product for high volume applications.
So the "73" chips are ROM versions while "79" chips are E-ROM versions ("FLASH like features").
