Hi!
This is my first post here, and I am hoping that someone in here can push me in the right direction as I am troubleshooting my KORG SE-500 tape delay.
The machine has no delay signal and I believe that has to do with the +side not delivering enough voltage. When I scope pin 7 on A1(4558 op amp) I get a nice reproduction of the sine wave that I send into the input. But it fails to deliver any output on pin 1. And I believe that is because the + side of the circuit I am only getting 5.2 volts in to the 7815-regulator(It is a new 7815-regulator), and and output of around 2.2v (If I measure pin 8 on any of the 4558 that is all I get). The bridge rectifier (S1VB10) reads 35v when I measure AC current between the two ~ points on the rectifier. It also reads around -35vDC on the negative side, and only +5.2v on the plus side. This leads me to conclude that the bridge rectifier is only working on the negative side. I don't have a new rectifier on hand, but I thought that this KBP02G would be a good replacement?
https://www.digikey.no/no/products/detail/diodes-incorporated/KBP02G/248715Can anyone confirm that this would be a good fit?
I believe I am on the right track, but would like to get some feedback if I am searching for faults in the wrong places. (attaching the schematics)
Thank you in advance!
Cheers,
Lars Ove
