The fusible resistor didn't just blow up on its own. You have to find the failed part that caused it to blow otherwise the replacement will blow up as soon as you connect power. It's probably the driver IC that failed. Your logic on the resistor value is way off, the wattage of the driver is unrelated, the resistor is probably a few ohms at most, just enough to limit the inrush, it is primarily a fuse.
