Obviously I have checked those. There's a fair few devices inside so a schematic would make things MUCH easier. Does anyone know anything about the company Levell? Haven't been able to find much.
By your reply it seems you are knowlwedgeable about such things. Schmatics are hard to come by online as companies want to protect their IP but they must have inspiration from somewhere first?
Please answer a few questions, Is TG303 mircroprocessor controlled as everyone knows one can make a software function generator plus the frequency counter? If it is fully a discrete design does it use opamps , transistors,resistors,capacitors and diodes to first generate a triangle wave then convert to square wave and then massage to a sine wave to finally to an amplifying stage? Does it have opamps like LM741,LM308, FET transistor, CA3086 transistor array, frequency counter ic, 2N2905 and 2N2904 medium power output ? Or does it use a ICL8038 or MAX038 ic function generator ?
