Author Topic: Load switches  (Read 1556 times)
Offline fzabkarTopic starter
Load switches
« on: February 10, 2022, 06:19:07 pm »
Could someone please identify these load switches ?
They are functionally and electrically identical to the following:
SiP32462DB-T2-GE1, Vishay Siliconix, 50 mOhm, Slew Rate Controlled Load Switch, Vin = 1.2V - 5.5V, 1.2A, marking AH, WCSP4:
https://www.vishay.com/docs/67754/sip32461.pdf
SiP32458, SiP32459, Vishay Siliconix, 20 mOhm, Slew Rate Controlled Load Switch, Vin = 1.5V - 5.5V, 3A, marking AA or AB, WCSP6:
https://www.vishay.com/docs/63999/sip32458.pdf
More information in this thread:
https://forum.hddguru.com/viewtopic.php?f=10&t=39872
I also need help to ID this component:
I'm guessing that it is an electronic fuse or another load switch. "CK" is the part code.
This appears to be the ballout:
+3.3V in   O  O   output
+3.3V in   O  O   output
+3.3V in   O  O   ground
« Last Edit: February 10, 2022, 06:49:18 pm by fzabkar »
Re: Load switches
« Reply #1 on: December 28, 2022, 06:04:18 pm »
I found this part which has a "CK" branding and compatible pinout, but it seems wrong because it is atypical for an SSD. The marking style seems similar to other Analog Devices packages, but I haven't found an image of this particular chip.
ADP1196ACBZ, Analog Devices, Logic Controlled High-Side or Low-Side Load Switch, 5V, 3A, 0V - 5.5Vin, marking CK, WLCSP-6:
https://www.analog.com/media/en/technical-documentation/data-sheets/adp1196.pdf
I haven't found anything on the "794DKI" part, but TI's TPS22954 load switch has a "ZDKI" marking, and "PDKI" is a power MUX (TPS2103) ...
« Last Edit: December 28, 2022, 06:12:28 pm by fzabkar »
