Author Topic: MCM68766 EPROM equivalent for my programmer?  (Read 1487 times)
Offline Staffan321Topic starter
« on: May 15, 2022, 07:29:49 pm »
Hello,
I have an MCM68766 8x8 Kib EPROM (https://www.datasheets360.com/pdf/-853472034809684633) that I would like to read with my TL866+. Does anyone have a suggestion for an equivalent that I can select as IC? This is a DIP24 and not a DIP28 like the 2764.
Many thanks in advance!
Regards,
  Staffan
Offline edavid
Re: MCM68766 EPROM equivalent for my programmer?
« Reply #1 on: May 15, 2022, 09:03:14 pm »
I don't see one in the supported device list.  I think you will have to make a socket adapter and use the 2764 setting.  The easiest way is to use 2 wire wrap sockets.
« Last Edit: May 15, 2022, 10:16:33 pm by edavid »
Offline fzabkar
« Reply #2 on: May 15, 2022, 09:49:04 pm »
Offline srb1954
  • Retired Electronics Design Engineer
« Reply #3 on: May 15, 2022, 10:00:32 pm »
Hello,
Check to see if your programmer has a device selection for MCM68366, which is the equivalent mask ROM to the MCM68766. There may be other manufacturer's mask ROMs that have the same pin-out as well.
If you can find an equivalent mask ROM selection you will be able to read the contents of the MCM68766 EPROM but I don't think you will be able to program the MCM68766 on the TL866 as it requires a 25V programming supply.
Offline edavid
« Reply #4 on: May 15, 2022, 10:17:33 pm »
The TL866 does not support any parts like that.
