Author Topic: Metcal MX-5000 repaired for not heating up  (Read 5102 times)
Offline gregplTopic starter
« on: October 21, 2017, 07:41:33 pm »
Didn't see this posted anywhere so thought it might help someone one day.
Was using my metcal mx-5000 and turned it off to replace tip then it wouldn't
heat up anymore. Everything else would work. When I picked up the iron to use
the bar graph did nothing and of course would not heat up.
Took it apart and found SMD diode D12 bad. SK16 -  https://media.digikey.com/pdf/Data%20Sheets/Diodes%20PDFs/SK12-SK16.pdf
Replaced the diode and its working again. Almost bought a new one. Glad I took it apart.
The following users thanked this post: oilburner, Zucca, neosenshi
Offline Zucca
  • EE meid in Itali
Re: Metcal MX-5000 repaired for not heating up
« Reply #1 on: October 23, 2017, 08:40:59 am »
Thanks gregpl, great job!
Offline memed
« Reply #2 on: November 07, 2017, 08:03:21 am »
Hi.
I have same issue with my MX-5200.
Did Q4 MOSFET was heating up that time?
Diode  D12 was shorted?
Thanks
« Reply #3 on: November 07, 2017, 02:15:17 pm »
I used an IR camera and could see D12 getting hot. It read shorted. Replaced it and its working now.
I didn't check any voltages or anything else. Just used the IR to see if anything was getting hot.
Offline helpmerepair777
« Reply #4 on: November 12, 2024, 01:30:17 am »
Hi , im new around here ! ehhe  :D
i was going to check this link https://media.digikey.com/pdf/Data%20Sheets/Diodes%20PDFs/SK12-SK16.pdf EDIT : the link is expired
its for the D12 diode , but the link is expired , and I wanted to know what SK12 diode to choose , im getting a used metcal mx-5000 and ordering come stuff from mouser so I told myself , why not get some spare parts , im gonna order thursday so let me know if you have any other spec for this SK12 diode
THANKS ALOT !
« Last Edit: November 12, 2024, 03:36:07 am by helpmerepair777 »
Offline Sajjad khan
  • Country: pk
« Reply #5 on: November 10, 2025, 05:06:36 pm »
Hi i am new here, having MX500 not heating up, My lm2576hvt get US repeatedly whether there is some short at output line which i don't find anywhere, i have checked Q1, Q2, Q3, Q4, U4, C4, C24, and many other components all measure good, i got reference from a Serviceable where i found difference of voltages at nagative sense point i.e  cathode of D8 they should be 7.5v but i measure 2.5 and at cathode of D20 it should be 3.5v but i found 1.5v.
Mention that these values are in stanby mode no hand piece connected, can any body help.
« Last Edit: November 10, 2025, 05:14:58 pm by Sajjad khan »
