The fuse blows for a reason: the stabilizer is being overloaded.Do NOT change the fuse to a larger value. The fuse blowing is a symptom, not a cause. The fuse is trying to protect your life, do not ignore its inconvenient message.
it's used for washing machine 530 W
That wattage number has a
lot of caveats, including (but not limited to):
(1) Peak vs average power
(2) Reactive vs real power
(3) Induction motors drawing more current when mains voltage sags.
It is very likely that your washing machine is blowing the fuse on your stabiliser.
How to do so correctly if it's viable, safe and reliable enough
Replacing a fuse with a breaker is possible to do, BUT, breakers are only rated to a certain number of trips and then need replacing anyway. Your actual problem is not the fuse, the fuse is your last line of defence.
