Author Topic: Monochrome LCD Character Display Identification (Buffalo Terrastation)  (Read 963 times)
Offline Mikek400Topic starter
  • Country: jp
Happy New Year to Everyone!
Have an LCD display that isn't working from a Buffalo Terra Station.
My first guess is the LCD need replacement. Not being super familiar with LCD displays I'm reaching out too see if anyone can help.
It is a 7 wire connection over a flat-flex connection. Not really sure if it is dot matrix or character.. It also lacks a reflector in the back because it is backlit.
It has the markings 1B14C on the flat-flex but doesn't seem to give any meaningful results upon searching.
I have attached pictures of the LCD below.
1968120-0
1968126-1
1968132-2
I also attached a picture I found of a working one  online if that helps any.
1968150-3
Thanks in advance.
« Last Edit: December 31, 2023, 08:10:24 pm by Mikek400 »
Offline inse
Re: Monochrome LCD Character Display Identification (Buffalo Terrastation)
« Reply #1 on: December 31, 2023, 08:18:49 pm »
It’s a character display, you can see the separate blocks.
7 wires is too less for standard 4bit interface, I assume it’s SPI
Online amyk
« Reply #2 on: December 31, 2023, 10:23:30 pm »
That's a COG 16x2 character LCD, serial interface - either I2C or SPI. You'll have to analyse the circuit to determine the pinout.
I could find 6 and 8 pin models, but haven't seen a 7-pin so far. Example:
https://newhavendisplay.com/2x16-character-cog-lcd-fstn-display-with-no-backlight-3v/
