Author Topic: Motor Identification  (Read 2268 times)
Offline JtroTechABTopic starter
  • Country: in
« on: May 16, 2019, 05:15:21 am »
Hello,
I have this motor (see attached Image).
I think it is Servo motor but I am not sure, kindly clarify.
As you can see there are three pins from the windings,  how to identify them?
  • Country: in
Re: Motor Identification
« Reply #1 on: May 17, 2019, 03:32:36 am »
Not sure about the type of motor. If anyone can explain.
Offline John.S
« Reply #2 on: May 17, 2019, 10:07:38 am »
It looks to me like a 3 phase asynchronous motor by the look of the coils and 3 connections coming out.
When you have 3 phase supply of the right value, it does not matter how you connect this 3 poles, it will run in a certain direction.
To change direction, simply interchange 2 connections.
From photo i can not see if the coils are connected Y or D, so you need some motor plate or datasheet to know the voltage needed.
greetings John.
Don't think in problems, think in solutions....
  • Country: in
« Reply #3 on: May 17, 2019, 10:49:10 am »
greetings John.
We dont have datasheet of this motor. But it has DC driving circuit.
Offline Gyro
« Reply #4 on: May 17, 2019, 10:53:31 am »
We really need to see a picture of the rotor to be sure.
Best Regards, Chris
  • Country: in
« Reply #5 on: May 17, 2019, 11:13:00 am »
Find the attached picture of the rotor.
Offline amyk
« Reply #6 on: May 17, 2019, 11:43:37 am »
I believe that's a switched reluctance motor.
Offline Gyro
« Reply #7 on: May 17, 2019, 11:47:00 am »
^ Likewise. There are no copper end rings to suggest that it's an induction motor.
Best Regards, Chris
  • Country: in
« Reply #8 on: May 18, 2019, 05:07:59 am »
Is there any way to confirm which type of motor it is ?
the only thing I am sure about it is that it works on DC supply.
I also implemented the driver ckt (see attached file)
with changes in resistor & capacitor value as I wanted 20KHz
and as you can see the expected output waveforms in the attached file but in the output I am getting
continuous straight line, why is it so?
Offline Gyro
« Reply #9 on: May 18, 2019, 04:50:04 pm »
The shape of the pole pieces and the 'lobed' shape of the laminated iron rotor are pretty conclusive, it's a (switched) reluctance motor.
Think of it as a stepper motor without any permanent magnets. The lobes get attracted to whichever combination of poles has the strongest magnetic field. By varying the signals on the three inputs, you can control the relative (not absolute) position. I would expect to see the windings driven by three H-Bridge drivers to be able to take combinations of windings high or low (if it's from a DC supply).
The circuit you show seems to be for a standard pulse width controlled servo, eg. A radio control model one. That's not what it is (unless there is an additional driver board that you are not showing us).
Similar motors are used as 'syncro receivers' (google both these and reluctance motors!) where the 'syncro transmitter' has a winding on the rotor which is driven (normally) at 400Hz AC. These are used for accurately transferring angular motion in an Aircraft. This is not a DC application though, and you seem convinced that it has been run from DC (which would need to be via a power driver as I indicated above).
https://en.wikipedia.org/wiki/Reluctance_motor
https://en.wikipedia.org/wiki/Switched_reluctance_motor
https://en.wikipedia.org/wiki/Synchro
« Last Edit: May 18, 2019, 04:55:19 pm by Gyro »
Best Regards, Chris
