I recently scored a HP 3457A for an amazing price. Unfortunately, the battery on the unit was dead, and as I am trying to replace it, I found the process to be a confusing, and I would like to share my experience, along with the information that I discovered along my journey.
The meter was constantly popping up with error code "9 NOT CAL'D". CALNUM showed 0, and the readings were a few thousand counts out of spec. It was still good enough for 4 1/2 digits. I only realized it was out of spec by comparing the readings to a calibrated 33401A. I opened up the 3457A, and, as you might have guessed, the cal battery had leaked, and was measuring 19 mV.
I was worried that the leak might have damaged the PCB, so I immediately proceeded to removing the battery. I took the digital board out, then snipped the pins off the battery. Not knowing the extent of the chemical damage, I was really worried I might strip a trace, or rip out a via.
I heated the battery pins from the back side of the PCB, then carefully pulled them out. I then proceeded to carefully remove any excess solder with some solder wick, then clean the residue off with 99% isopropyl alcohol. PHEW! The PCB is in mint condition. The corrosion was contained to the positive baterry pin.
Even having the dead battery, I had difficulties figuring out what to get as a replacement. I started with the inscriptions on the cell:
ETERNACELL SDX
3 VOLTS No. B9511
H.P. P/N 1420-0278
Searches for those part numbers turned out empty. I spent the next few hours measuring the dead cell, and comparing its dimensions to specs for other lithium batteries. Turns out that this is a:
2/3 A size (not 2/3 AA)
At this point, I also found some eevblog posts about this, and people were replacing them with either 3 V or 3.6 V cells. I was able to find the service manual, and the schematic eased some of my fears.
The NVRAM rail, NVVCC, is a 5V rail. The battery feeds this rail through a diode, CR504. Alright, so anythng between 3V and 5V will work. Now it's time to find the right battery. The only battery that I could find on digikey that had the right PCB mounting pins was the Panasonic P226-ND.
I decided to order the battery, but to first attempt installing a battery holder. Someone else on the eevblog forum already tried the battery holder, and they couldn't get it to fit quite right. I decided to order every 2/3 A holder that Digikey had to sell in the hope that one will fit.
I'm still waiting on the parts, and I will update this as I go along. Please excuse the crudity of the images. I only had a phone available to take the pictures.
