Author Topic: NAD 3140 - regulated power supply - solved  (Read 847 times)
Offline willbTopic starter
« on: November 20, 2024, 06:57:09 pm »
Good day all!
I have been chasing my tail for 2 days over this issue and can't seem to get anywhere.  |O
Basically, the positive rails in the power supply are good but the regulated negative side is no good. All the semi-conductors test OK out of circuit in my DCA75 tester. I replaced the few electro caps, no difference. All the resistors are good. I have attached a photo of the schematic with the voltages I have in red at the measured point. I am at a loss.
Any insight would be greatly appreciated!
Cheers!
« Last Edit: November 20, 2024, 10:53:02 pm by willb »
Offline Messtechniker
Re: NAD 3140 - regulated power supply
« Reply #1 on: November 20, 2024, 08:15:29 pm »
According to your measurements that BD 140 with both collector and emitter voltages at at 55 V shoud be dead.
If on a heat sink, bad isolation could be shorting out this BD 140.
« Last Edit: November 20, 2024, 08:17:20 pm by Messtechniker »
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
« Reply #2 on: November 20, 2024, 10:52:46 pm »
it's fixed.
Someone was in here before me, replaced Q808 but installed it backwards, swapping the emitter and the base.  :palm: :palm: :palm:
