Author Topic: NAD C325BEE Will not power.  (Read 9782 times)
Offline Kim Christensen
Re: NAD C325BEE Will not power.
« Reply #75 on: January 27, 2022, 11:56:38 pm »
Kim Christensen thank you for all your helpful advice!!! I certainly would not have managed to repair this if it wasn't for your excellent help!  :-+
You're welcome. It was a fun exercise for me as well. Good to hear that all is working now.  :)
Offline paul_g_787Topic starter
« Reply #76 on: January 28, 2022, 12:04:26 am »
Indeed! I do love a challenge and it is good to have some expert help as well!
I learned a lot more than I knew before about how amplifiers actually work from this one. It was good fun! 😁
Offline Per Hansson
« Reply #77 on: January 28, 2022, 07:20:54 pm »
I would replace the SMD caps on the other module too, if you re-read my post #40 you will see they where bad on both.
« Reply #78 on: January 28, 2022, 10:10:17 pm »
I checked the ESR on them both in circuit and they were 0.3Ω and 0.7Ω (I forget which was which). Which I didn't actually do on the other module.
I didn't want to tempt fate and remove the module if I didn't need to just in case I made it worse! I had a very hard time soldering those SMD parts as it is!
Offline jhjove
« Reply #79 on: March 22, 2022, 07:39:42 pm »
New to the forum (typically on diyaudio and audiokarma) and 2+ months late to this topic. Quite a nice dialogue and repair. :)
FWIW, I went through an almost exact repair sequence in February 2021. I acquired a C325BEE (a for-parts-only special) from ebay.
Although in addition to the +/-18V power supply issues, the main power board was fried on my amp. In the end I have a very nice working amp.
I wanted to add that the failed SMD caps on the CB21 + CB22 riser boards I replaced with similar SMD form-factor parts, but solid-polymer type electrolytics.
Again, I enjoyed the thread, very good info.
Offline FIXITNOW2003
« Reply #80 on: March 23, 2022, 07:50:57 am »
not seen a 325 but have seen some 320 versions these do suffer with poor elec caps  in the protection circuit. and output stages i would check the to see if esr is poor
Offline Mathijs
« Reply #81 on: February 15, 2024, 02:41:36 pm »
Now 2 years later (february 2024) I am experiencing a similar problem with my now 18 year old C325BEE NAD amplifier. Thanks to paul_g_787, Kim Christensen and other readers I was able to repair it. My C325 switched off again after a few seconds after being switched on, so from amber to green and to amber light again. The ultimate cause was the SMD caps in the pre-Amps that may have leaked (C203/204/C103/104). I replaced all SMD caps with new ones, after which the amplifier switches on again without errors. Considering the age, I immediately recapped the entire power supply. It was a bit of a job, but for now the C325BGEE can last for a while. Thanks everyone !
« Last Edit: February 15, 2024, 02:43:57 pm by Mathijs »
