Author Topic: NEC Multisync LCD 1550X knackered  (Read 1831 times)
Offline MesstechnikerTopic starter
« on: November 11, 2018, 08:44:29 am »
My good old NEC Multisync LCD 1550X monitor has partly given up the ghost. See pics. It’s definitely the monitor since VNCing into it is fine and signals from both inputs (VGA from a PC and DVI from a scope) are affected. Has anyone seen this symptom for a quick fix? Of course I will take it apart as a last attempt before it goes into recycling.
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter
Offline mzacharias
Re: NEC Multisync LCD 1550X knackered
« Reply #1 on: November 11, 2018, 01:06:08 pm »
I would definitely start by checking the power supply caps. Very common problem on similar models.
The following users thanked this post: Messtechniker
« Reply #2 on: November 13, 2018, 08:45:26 am »
The 5 electrolytics on the psu board are on my next order list now (all low ESR types) which will go out in a couple of weeks.
Did only measure the 150 uF/400V cap:
Measured as 127 uF (i.e. too low) and ESR was 0.5 Ohm which is OK (according to my list). At the time this LCD was manufactured (2004) all electrolytics used to be above their nominal value when new.
Will have to wait and see. :popcorn:
By the way: the service manual for this LCD is extremely detailed. Basically down to the last firmware bit everything is explained in enormous detail. Never seen anything like this for a LCD before. :-+
Offline james_s
« Reply #3 on: November 18, 2018, 08:18:28 pm »
That's impressive, that was a high end monitor in its day though. I remember when LCD desktop monitors first came out, they were expensive and only the upper manager types had them at work.
« Reply #4 on: January 14, 2019, 02:23:15 pm »
Well, not the capacitors this time :(.
The PSU board was OK also after replacing the caps.
Apparently the fault was on the video board.
Unfortunately beyond repair.
Its parts are now in the electronics waste bin after salvaging a few bits and pieces. So sad.
Its bother (Multiscync LCD 1550V) is now in place for the rest of its life.
Since it does not have a DVI port, I can now no longer display the screen of my HMO 1022 scope.  :palm:
Maybe a small monitor with a DVI and a VGA port will drop off a bench somewhere - hopefully some time soon. :popcorn:
Offline wraper
  • Country: lv
« Reply #5 on: January 14, 2019, 02:58:36 pm »
Did the same thing happen with OSD? IMO it looks like faulty LCD panel.
« Last Edit: January 14, 2019, 03:00:35 pm by wraper »
Offline Armadillo
« Reply #6 on: January 14, 2019, 03:27:03 pm »
Yeap, Faulty LCD Panel.
Offline Bashstreet
« Reply #7 on: January 14, 2019, 05:39:30 pm »
Any special reason to fix it ? getting new one with better specks second hand very cheap.
« Reply #8 on: January 14, 2019, 08:25:30 pm »
Just for the heck of it. The use case, i.e. mucking around with non-activated W10
does not even warrant the price for a used monitor. Had a spare one anyway.  :-+
And also a further free spare for the spare is at hand. :palm:
Offline james_s
« Reply #9 on: January 15, 2019, 08:54:07 pm »
I fix a lot of stuff just because I can. There are certainly less useful ways to pass the time.
