Author Topic: Need help identifying burnt component ASUS G751JY  (Read 13916 times)
Offline wraper
  • Country: lv
Re: Need help identifying burnt component ASUS G751JY
« Reply #25 on: May 10, 2018, 08:07:11 pm »
It's a ferrite bead. For starters you could just short it with a piece of wire and see if it works. Also would be worth to check if there is no short to ground. It everything works, then you can either buy some ferrite bead of correct size and at least 3A current rating. Or leave as is, it won't affect functionality.
Offline hal0000
  • Country: tr
« Reply #26 on: May 10, 2018, 08:42:53 pm »
I don't think there is short something else because of everything else is fully functional so you saying use 3A and ohm is not important ?
and if i just remove that Ferrite Bead with screw and leave it ? or soldering ?
And if i use my laptop like that does it hurt something else ?
Offline wraper
  • Country: lv
« Reply #27 on: May 10, 2018, 10:00:40 pm »
It's there for some noise suppression. Actual value is not critical. There is no other way to know original value other than finding the schematic.
Don't understand what you mean. Just desolder it and short the pads with a piece of wire to check if everything else is fine.
Offline hal0000
  • Country: tr
« Reply #28 on: May 10, 2018, 10:03:49 pm »
I will desolder and short the pads like 7 days later but i must buy ferrite bead just incase so 3A and 1608MM is enough ? or Ohm is important too ?
30+25% to what ? can i use 70 ohm too ?
Offline wraper
  • Country: lv
« Reply #29 on: May 10, 2018, 10:13:30 pm »
You basically can use any rating as long as current spec is high enough.
Offline hal0000
  • Country: tr
« Reply #30 on: May 10, 2018, 10:16:19 pm »
This Ferrite Beads is really hard to find in my country and shipping from other countries is non sense shipment prices like 25-75 €
so as long as higher then current specs is everthing is okay ?
Offline wraper
  • Country: lv
« Reply #31 on: May 10, 2018, 10:21:05 pm »
Yes. if it is hard to source, just short the pads together and leave like that. You could look on ebay or aliexpress. It will be more economical to buy a single part there.
Offline hal0000
  • Country: tr
« Reply #32 on: May 10, 2018, 10:23:20 pm »
Sorry for being and amateur but "short the pads" you mean desolder the broken beads and leave it like that ? or solder with wire ?
Offline wraper
  • Country: lv
« Reply #33 on: May 10, 2018, 10:24:43 pm »
The following users thanked this post: hal0000
Offline hal0000
  • Country: tr
« Reply #34 on: May 10, 2018, 10:27:00 pm »
solder with wire indeed
Thanks man i can only try on next week. I will update this thread when i did the solution.
Offline hal0000
  • Country: tr
« Reply #35 on: May 11, 2018, 09:55:29 am »
I purchased this:
Wurth Elektronik Ferrite Bead (EMI Suppression), 1.6 x 0.8 x 0.8mm (0603 (1608M)), 30Ω impedance at 100 MHz
DATASHEET PDF:
http://pdl.designspark.com/api/v1/manufacturers/53f321fc9b4759f8699d4316/part/53f3300d9b4759f869bb2d9f/5491d8489b47599b72937df5/1pdf
Offline wraper
  • Country: lv
« Reply #36 on: May 11, 2018, 10:21:21 am »
should do the job
