Author Topic: Nichicon Electrolytic Capacitors leaking - common problem? ( Rifa X and Y also)  (Read 12010 times)
Offline free_electron
    • SiliconValleyGarage
no point in griping about capacitors that have gone bad after 30 years of life ... most capacitors have a lifespan of 2000 to 5000 hours ... you do the math.
The following users thanked this post: rsjsouza
Offline Fraser
@Wrapper,
This was the article that I read. Maybe I misinterpreted what it said about X type capacitors and protective devices etc.
https://www.allaboutcircuits.com/technical-articles/safety-capacitor-class-x-and-class-y-capacitors/
Fraser
Offline james_s
That's usually the quoted lifetime at the maximum rated temperature and full rated voltage. In practice I would expect the operating life to be considerably longer, but still 30 years is hard to complain about.
Offline Jay_Diddy_BTopic starter
I just replaced the Rifa capacitors in an HP 6632A power supply. Like a lot of these supplies you have to remove 80% of the screws in the unit to get access to the bottom of the circuit board. The transformer and the transformer bracket have to be removed.
Overview
The capacitors are toward the rear of the unit
Input Capacitors
Output Capacitors
There are Y rated capacitors on the output.
Parts needed
2x 2200pF 10mm Y caps
2x 4700pF 10mm Y caps
1x 0.22uF 20mm X cap
The unit was around 1995. All the capacitors were cracked.
Regards,
Jay_Diddy_B
« Last Edit: October 28, 2020, 09:10:24 am by Jay_Diddy_B »
The following users thanked this post: bd139, FransW
Offline Haenk
Unfortunately, a) the manufacturers did not expect their products being in use for more than 30 years and therefor didn't plan for easy replacement and b) the failure is only common to certain products (like those wicked RIFA x/y caps), which might be a problem of manufacturing control or general construction, but not a "all caps are dead after 30 years".
Offline wn1fju
This is my new hobby - replacing Rifa suppression capacitors.  So far I've replaced 52 of them!  Almost all the X-caps were cracked as were about half of the Y-caps.  Some are particularly hard to get to, for instance when they are right at the AC receptacle and inaccessible without pulling off the back panel.
I bought about 80 non-Rifa suppression capacitors of assorted values a few weeks ago.  I've exhausted most values.  Time for a new order.  I've got a few more HP pieces that I suspect have Rifas.
Offline Haenk
They are simply everywhere. Last I have seen were in a Sony CDP-101, what a surprise. Cracked, of course...
Offline syau
  • Country: hk
I usually replaced them with Panasonic X1 / Y1 rating due to higher line voltage.
Offline wraper
  • Country: lv
I had equipment at my previous job with those Rifa caps in mains filters occasionally exploded starting from about 2015-2016. Those were made in about 2004-2005. So more like 10 years instead of 30. It needs some talent for continuing making this shit for many decades without any fix.
« Last Edit: October 28, 2020, 05:09:52 pm by wraper »
don;t forget the ones hiding in many shaffner netfilters inside hp and other equipment ...
Offline syau
  • Country: hk
Those Shaffner which have voltage selection “wheel” never come cheap  :palm:
Offline floobydust
The real issue is the cracking - is the epoxy shrinking or paper absorbing moisture and ballooning out etc. They're old parts, designed before mains transients standards were established. Surely they've been updated in design?
I'd emailed Kemet and told them the PME271's are a POS and why are you still selling them? <crickets>
They're an odd part- "impregnated paper" with no self-healing unless marked "SH". Most datasheets for them say nothing about any self-healing ability. I've never measured any to see if they went low value due to aging.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
I'd emailed Kemet and told them the PME271's are a POS and why are you still selling them? <crickets>.
While there are buyers for these things, there'll be production. Keep in mind that manufacturers might not be able to change designs (qualification, perhaps?) or simply don't care for the future of thr equipment - especially if these sell cheaper that other ones more robust.
How are we going to compete?
1) Total number changed?
2) Total weight of Rifa X and Y caps changed?
3) Total number of uF changed?
4) Total number of screws that have to be removed to get to the most difficult little ba$tard?
 :-//   :popcorn:
Jay_Diddy_B
« Last Edit: October 29, 2020, 01:14:00 am by Jay_Diddy_B »
Offline james_s
In most cases there is no business reason for them to care. The capacitors we are talking about are ~30 years old. How many companies support anything once it is that old? The other day I worked on a ~12 year old $40,000 veterinary ultrasound machine, the manufacture wanted nothing to do with it and refused to provide any support, the medical equipment repair vendors turned it down too because it's "too old", so I fixed it. Once a piece of equipment is out of production and out of warranty most companies prefer if it fails sooner than later.
And these caps, at least in 120V land are not that big of a deal. I've had a grand total of ONE of them burn up, I'm sure I've got lots of them in various gear, I've never replaced one preventatively, ever. If any more of them burn up I'll replace them after the fact.
The following users thanked this post: rsjsouza, SilverSolder, syau
Offline wn1fju
Jay_Diddy_B writes, "How are we going to compete? Number, weight, etc... "
This is not a competition I am eager to win!  With Rifa capacitors, everybody eventually loses.
I have gone through most of my pieces, but there are a few more HP pieces that I know have Rifas and a few more that I suspect also do.  Why is it that those pieces are on the bottom of my stacks with 10 heavy pieces above them.  My back already hurts from moving a ton of equipment around.
Photo shows the carnage so far... 57 Rifa caps preemptively replaced.  Many of them look far worse in the picture than I originally found them.  This is because I often found it easier to remove the cap from the component side (when getting to the foil side looked like a pain in the butt) and so were chipped or cracked or mauled by rocking them with pliers until they pulled free.
Most of the casualties were from HP and Tektronix pieces in the 1980s and early 1990s.  The worst offender was the HP 8160A pulse generator with nine Rifas, followed by the HP 6621A power supply with seven Rifas and the HP 8080A word generator with six Rifas.
Whereas most of the Rifas are lurking right near the AC jack on the back panel, there were a few cases where HP used them in "non-standard" places, like after the diode bridge in the switching power supply of the HP 3764A digital transmission analyzer or on the output of the HP 6621A power supply.
I didn't do anything with the sealed line filter modules found in many pieces.  I know Schaffner has a bad reputation, but replacing Rifas at about 35 cents a pop (no pun intended) is a lot nicer than $30/each for a line filter.
I will probably end up with a count of about 70 Rifa caps replaced.  Maybe I will glue them all to a piece of cardboard, frame it, and hang it on the wall.
Offline james_s
That sounds like hoarding to me. Are you actually using that equipment?
Offline wn1fju
Recent post:  "That sounds like hoarding to me. Are you actually using that equipment?"
Some people call it hoarding.  Some people call it collecting.  Some people call it "GAS."  Some people belong to "TEA."  Some people enjoy fixing and restoring test equipment.  Some people are building up a metrology grade lab.  There is plenty of room for everyone in this hobby without being judgmental.
As far as using my equipment, I use the N pieces I have to fix the (N+1)st piece when it arrives.
N is currently equal to 409, all of them fully operational and used more frequently than you would think.  If that is your definition of hoarding, so be it.
Offline rsjsouza
  • Eternally curious
Well, if you are the same WN1FJU listed in the 1956 callsign book, then you had plenty of time to get all this gear.  :-+
(you can find a lot of stuff on the internet these days...)
Offline wn1fju
I give you an "A" for the detective work.  But, alas, that's not me.  I was first licensed in 1965.  Still, plenty of time to amass my collection (actually, I started about 20 years ago).
Offline rsjsouza
  • Eternally curious
Just a Google search away... Not really much.
Offline james_s
I mean people can do whatever they want, I certainly have hoarding tendencies myself, which is one reason I try to be aware of it and actively think of why I have something and resist the urge to buy something I already have just because it's a good deal. I know guys who have 5 or 10 of the same item collecting dust on a shelf and usually when they pass away family members are so desperate to clear out everything so they can sell the house that not knowing what is valuable and what is junk everything ends up in a landfill. It also annoys me to some degree when there are people with zero of something because someone else is sitting on a whole pile of them and buying up every one that comes along.
Offline wraper
  • Country: lv
Hoarders getting rid of their stuff does not mean "people with zero of something" will suddenly get that something. They probably don't have "that something" because they never bothered to get it (find it/pay for it/repair it). Most of it goes to a landfill anyway and hoarders collect only a tiny part of old equipment.
« Last Edit: October 29, 2020, 10:48:55 pm by wraper »
Offline Shock
Now there is a man, who really likes smoking rifas.
Offline Daniel Dufresne
Hi, thanks for the information. Are the failed RIFA capacitors all PME 271 type ?  Most of the PME271 I have, even the new old stock, NOS, have cracks. I also have RIFA PMZ2050M NOS but without cracks. Regards.
