I saw that note, but nothing saying what those two caps are. I can barely read "100" on both of them, and "1%". I don't think either one is 22pF.
Correct, they're as listed on the schematic.
C2 3.3nF or 3300pF or 332
C4 0.47uF or 470nF or 474
Guessing both are MLC and 100V, fairly normal values for this old stuff.
Even green caps should work.
For a sanity check.....measure them.
C68 (note 2) is only the revision after SN 5050 when this 22pF cap was added.
No other changes are listed for the primary side of T102.
As your unit has the C68 change and it seems you've found no other discrepencies, trust the schematic.
