Hi All!
I have been using a lot of MBed boards for development lately because they are so cheap and have so many of the embedded setting pre-configured.
However, I have been having a problem with some of the smaller Nucleo boards (the ones designed to fit the Arduino Nano footprint), primarily the Nucleo-L432KC.
It seems that I have a power problem, and I don't really understand the design.
I powered the board through the "VIN" pin via 2-cell LiFe battery. The board uses a LD1117S50 (U6 in the schematic) as a regulator and it should be OK for voltages up to 25V. It is possible that I plugged in the power and ground backwards?
However after powering the board, the high-side power switch (U1 - ST890CDR) ran very hot. Now when I plugin via USB, the device shows up on my computer and appears to work, however the 3.3V bus seems to be around 1.9V and the ST890 is very hot.
I have setup LDO regulators before but have never used a high-side switch before. According to the datasheet this is there to protect everything in case of a short circuit, as best I can tell.
When I measured the resistance between the 3.3V bus and Ground its about 390 Ohms, so clearly there was a short.
I figured that maybe I had blown the "VIN" regulator. So I removed it from the board, but it exhibited the same behavior as before (1.9V on the 3.3V bus). Likewise, I did the same thing with the 3.3V regulator and had the same result.
Does anybody have any insight as to how this circuit is supposed to work and what component may have failed?
I have included png's of the schematic. All the design files can be downloaded here:
http://www.st.com/en/evaluation-tools/nucleo-l432kc.html
