Hello all,
I've been handed over a JBL GTO 75.4 4 channel 104W RMS Amplifier but im having some issues with it.
When testing the unit in the lab I noticed terrible performance and output power was only about 56W of the 280W (bridged outputs) available. I decided to hook it up to the scope and turned the input volum up and the attached image is the combined waveforms of the volume levels.
There is a moment that the signal starts to clip, but its not a "hitting the rail" kind of clipping I would expect. This happens with all channels on the amp.
According to the previous owner the unit worked great. Now the speaker smells of hot enamel from the "DC" clipping.
There is no power supply shortage, 14.4V 30A power supply and a 2-5F capacitor 15cm from the amplifier power connection. Poked it with a scope and nothing to see there.
After thinking for a bit I've been using a tone generator on my phone to test the lower frequencies so thats the first thing I will check today with a proper signal generator.
Other than the source signal being inadecuate, is there anything else to check for? I believe it's a class AB amp.
Thanks and regards!
