Hello everyone, I recently picked up an Onkyo TX-SR 508 7.1 AVR, so I don't know much about its history. it works very well but I have a small problem on one of the output channels.
On the left rear surround channel, the sound is less loud than on the other channels. But I can make it come back to normal by increasing and decreasing the volume.
Let's say that the volume level is set to "10", all channels work but the left rear surround channel is weaker than the others. However, if I briefly set the volume to "20" and then lower it back to "10", the problem disappears and the channel produces the same sound level as the others. It seems that increasing the volume "unblocks" something in the amplifier.
I've already tried with another speaker, and another cable, but the problem is still there. I also tested the transistors, I did not see any anomaly. I also removed the dust inside. All connectors seem to be good.
Have you ever had this kind of problem on an amplifier?
All answers are welcome! I thank you in advance for your help
Here is the service manual, if you want to see it (need to scroll down a little for the DL link) :
https://elektrotanya.com/onkyo_tx-sr508.pdf/download.html(Ps: little update about my post for my oscilloscope, unfortunately I didn't have time to take care of it, but I will keep you informed!)
