Author Topic: Ono Sokki CF350 FFT : repaired  (Read 12652 times)
Offline pinball
  • Country: at
Re: Ono Sokki CF350 FFT : repaired
« Reply #25 on: November 23, 2019, 06:05:16 pm »
Hello Alex, do you have scanned the full user guide yet ? I am not sure if my CF-350 is defect or i made incorect inputs.  Thank You so much,
Helmut
Offline reinhold-m
« Reply #26 on: October 16, 2021, 05:17:17 pm »
Hello,
may you be so kindly and check what type of floppy is installed in the FT350/360? The floppy in my FT360 has been replaced years ago and now it isn't possible to read/write disks. The activity-led doesn't get off (with or without an inserted floppy disk). All other functions aro o.k., and using the format option in the disk utility menu starts the format process as expected - an error occurs after finishing the last sector: "RD-WT-ERROR". Due to the missing label on the replacement floppy I'ld ask for more information about it - hoping someone is able to tell me the manufactor and type.
Thanks in advance,
Reinhold.
Offline psykokTopic starter
« Reply #27 on: October 29, 2021, 06:16:42 pm »
Unfortunately I cannot help, my floppy drive is also not working and brings error when I try to use it.
I tried to change it with an other drive I had in my stock without any success.
I suppose this instrument needs a special kind of floppy drive
Alex
