Firstly, don't install the 2 IGBTs, you need to ensure that both bases are not high at same time.
A. Measure Voltage at IC9602 - Pin 4 wrt Pin 3 and Pin 7 and Pin 3, make sure both not high at same time.
B. Then, make sure T9604 are not fused/shorted. You have to take it out to ring test it.
If both pass, then install the IGBT and run it using series light bulb test.
Above my opinion, the way I would proceed it.
