I have this panel meter connected to my solar panel.
http://www.mpja.com/download/32541medata.pdfIt was working great, but I noticed the voltage reading seemed too high. It was fine when new. I installed a 2nd panel meter on another solar panel and it too was fine, but the voltage reading became suspiciously high.
I too the panel meter to power supply and inject 12V and it reads ~18V. I pulled the back cover and noticed 3 ICs, a RTC crystal, and a handful of passives.
So I wonder, since this happened to two panel meters, if the solar panel starts to act as a load and wipes out calibration data on an IC? This seems unlikely though because I would expect the entire code to become corrupt - the device seems too simple to have separate memory just for cal data.
So, without any pots, I guess accuracy is either designed or calibrated in SW and there is nothing that can fix these?
I can post a pic of the PCB later.
