Author Topic: Part identification: Worn down switch  (Read 2328 times)
Offline thfTopic starter
  • Airport Technician (Electronics)
« on: June 05, 2017, 08:07:16 pm »
Greetings
The hood in my kitchen is failing me, its the on/off switch that's worn down. I'm usually the parts procurer/finder at my job, but my searches come up blank.
I hope someone knows the markings on the switch.
Thanks in advance
Offline Armadillo
Re: Part identification: Worn down switch
« Reply #1 on: June 05, 2017, 08:27:46 pm »
Pry Open it up from the plastic slot slowly and clean the contacts with deoxit.
Offline Neomys Sapiens
« Reply #2 on: June 05, 2017, 11:56:04 pm »
Manufacturer is either Schadow or Schurter
Offline Gyro
« Reply #3 on: June 06, 2017, 09:38:32 am »
It's unlikely that a mains switch is suffering from contact oxidation, more likely is that the contacts or mechanism are worn out. A worn and arcing mains switch is a fire hazard.
Best Regards, Chris
« Reply #4 on: June 06, 2017, 07:50:22 pm »
Hi all
Thanks for the inputs! Didn't think to clean the contacts. However the wifu managed to kill it completely today, and that left a skid-marks on the PCB.. It was a bad solder on one of the pins! So a bit of solder managed to salvage the hood.
What a crappy circuit design they made though.. All wires a connected on a single board with spade connections..
Thanks again!
