You're right about the reistors, they don't look good, but they do not seem to be associated with the power supply, at least not the VCC. There are other components on the board that look similar, however, and I'm considering resoldering.
The signal on gate looks clean, no noise. It is very close to 0V when the power should be on, but the MOSFET is not condicting, 0V is measured on drain. This contradicts my theory that drain was directly con I think the MOSFET is blown for some reason, perhaps I short circuited something while working with it. Something else than the MOSFET must be dragging VCC up, and I can measure a diode voltage drop of about 600mV between the MOSFET output and VCC of the HC08 nearby. What is then pulling VCC to 1.2V? I don't know but I obviosly need to replace the MOSFET.
