Hi Harry_22.
Normally, the upper shield cover is closed,Press the "LOW RANGE ENABLE" button, the 2Mhz MAX indicator will light up.
If I test TP1, only the upper shield cover can be opened,Then when I press the "LOW RANGE ENABLE" button, the 2Mhz MAX indicator does not light up,Looks like the "LOW RANGE ENABLE" feature is gone,It may be caused by too much interference,The GND connection line is also connected normally.
In other words, if the upper shielding shell is opened to measure "LOW RANGE ENABLE", it will not be possible, so how should I measure it?
