Author Topic: Please help me identify these Unknown Components  (Read 1150 times)
Offline ThermallyFrigidTopic starter
« on: May 26, 2022, 02:12:26 pm »
Hello!
I have a small circuit board that I think is a PFC board, but I'm not sure.
It's a smaller board, on a 48v LiFEPO4 battery charger.
The unknown components are marked as UK1, UK2 and UK3
I realize I may have to desolder them to test them better, but I was wondering if they could be identified without doing so.
Here are the measured characteristics and a photo......
UK1
Resistance Test: 2.18K ohms with VOM leads connected either way
Capacitance Test: No reading regardless of VOM lead connections
Diode Test: Beep and 0.728v when positive lead on Left, 1.6v when Positive lead connected on Right side with no VOM beep.
Continuity Test: No continuity regardless of which way the leads are connected
UK2
Resistance Test: 6.93M ohms with VOM Positive Lead connected to the bottom, Negative lead to the top terminal, 5.17M when the leads are reversed
Diode Test: Beep and 0.643v when positive lead on top terminal, 1.988v when Positive lead connected to bottom terminal with no VOM beep.
UK3
Resistance Test: 0.740K ohms with VOM leads connected either way
Capacitance Test: .0L reading regardless of VOM lead connections
Diode Test: VOM Beep and 0.803v when positive lead on top terminal, 0.807v when Positive lead connected to bottom with VOM beep.
Continuity Test: No continuity regardless of which way the leads are connected - 0L
« Last Edit: May 26, 2022, 02:14:27 pm by ThermallyFrigid »
Offline fzabkar
Re: Please help me identify these Unknown Components
« Reply #1 on: May 27, 2022, 02:32:04 am »
Whenever I see a white smd component, I expect it to be a precision component. I've seen quite a few precision resistors, but no capacitors. However the following article suggests that your mystery component may indeed be a precision capacitor.
https://www.elprocus.com/what-is-a-smd-capacitor-types-its-applications/
The capacitors like NPO and COG ceramics are generally available in white color. They have less capacitance that ranges from 1pF to 10pF.
The following users thanked this post: ThermallyFrigid
Offline strawberry
  • Country: lv
« Reply #2 on: May 27, 2022, 07:12:04 am »
definitely not precision for product that cost 10$ , lucky getting 5% parts
0.47..1nF capacitors for TL494 timing and feedback compensation
sometime they solder some resistors upside down (to cut price?) but seems not in this case
Offline gamalot
  • Correct my English
    • Youtube
« Reply #3 on: May 27, 2022, 07:49:51 am »
They look like common ceramic capacitors to me.
Offline picburner
« Reply #4 on: May 27, 2022, 03:11:46 pm »
I found only one other pcb on the net called "XLS3.PCB" and it is also a different revision.
However in the latter UK1 and UK2 would appear to be capacitors while UK3 would appear to be a resistor.
This pcb, from what I could understand, should be part of a 60V lithium battery charger.
« Reply #5 on: May 27, 2022, 11:01:42 pm »
That would seem to make sense, but oddly, I have two of these and on one of these boards they used a LM358 and on the other an OPA1612 (which is a prohibitively expensive OpAmp for such a low cost device?
Well, if you buy these chargers they cost about $60 I believe.
Offline MathWizard
« Reply #6 on: May 28, 2022, 12:26:54 am »
Have you mapped out the circuit ? That would help a lot too, to guess what they are
Offline strawberry
  • Country: lv
« Reply #7 on: May 28, 2022, 05:56:07 am »
could be the same LM358 to get into 10$
« Reply #8 on: May 29, 2022, 01:58:39 am »
I'm mapping out some of it in an attempt to do just that.
Thanks
Offline fzabkar
« Reply #9 on: May 29, 2022, 02:03:37 am »
definitely not precision...
I consider NPO capacitors to be precision types (if that's what they are), but maybe others would not.
Offline strawberry
  • Country: lv
« Reply #10 on: May 29, 2022, 05:17:12 am »
NPO (C0G) better tempco and less microphonic
can get precision between +/-1pF...20%
https://eu.mouser.com/ProductDetail/YAGEO/CC0805KRNPO9BN102?qs=57cj7OiSijl0sOrTylTGAQ%3D%3D
Offline DavidAlfa
« Reply #11 on: May 29, 2022, 06:51:30 pm »
I'd say they're 100pf or so.
1nf+ are usually slightly darker, but doesn't always apply.
