EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Possible? - skiping mains power circuitry and injecting power after rectifier
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Possible? - skiping mains power circuitry and injecting power after rectifier (Read 1020 times)
mlindroth
Newbie
Country:
on:
October 29, 2021, 02:08:01 pm »
Hello all,
I'm trying to probe a malfunctioning PCB and would like to power it on the bench without having mains voltage on the board. Is it possible to inject 12V power after the diodes in the full-wave bridge rectifier and filter capacitor?
Thanks!
Logged
bdunham7
Super Contributor
Country:
Re: Possible? - skiping mains power circuitry and injecting power after rectifier
Reply #1 on:
October 29, 2021, 02:11:02 pm »
Yes, this is a common way to test boards out-of-chassis or when there is an issue with the mains supply. You do have to know for sure what the voltage is supposed to be and have a current-limited or protected power supply. You can also supply the power before the bridge rectifier if you remove the transformer leads. In any case, you should be careful to first check that the problem isn't actually in the bridge rectifier itself.
Logged
A
3.5 digit
4.5 digi
t
5 digit
5.5 digit
6.5 digit
7.5 digit DMM is good enough for most people.
mlindroth
mlindroth
Newbie
Country:
Reply #2 on:
October 29, 2021, 02:14:10 pm »
Thanks, I have checked it in place hooked up to mains. The transformer is outputting 12V, and the FWBR is working. I believe that for some reason the microprocessor is not outputting PWM pulses, or not supplying 10V to the blower motor.
Logged
fzabkar
Super Contributor
Country:
Reply #3 on:
October 29, 2021, 08:09:55 pm »
One possible, remote caveat is that some circuits monitor the frequency of the supply to synchronise their real time clocks or to detect zero crossings for TRIAC switching.
Logged
mlindroth
Audiorepair
Frequent Contributor
Country:
Reply #4 on:
October 29, 2021, 08:42:15 pm »
Yes, and there is also the case where the circuitry monitors the AC supply, so if this suddenly disappears, there is a "fast off" circuit that mutes the audio before Big Bangs blow the speakers.
Logged
mlindroth
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
