Next patient is a Power Designs 4050 40V/5A supply. It's a beast, 15kg and scary. This is one of the types that has a Variac autotransformer ganged with the voltage control pot. It varies the raw AC presented to the rectifier, tracking the output demand to give a constant voltage drop across the output transistors. Serial #010018 was assembled early 1980 and came to me neglected and dirty, but “sort of working.”
Indeed, pilot light came on, about the right output voltage came out the bananas, and the panel V meter followed; but only as long as there was no load.
Drawing any load whatsoever, even tens of mA, the voltage shot up *higher*. Same happened if one activated current limit, by dialing the control to zero. If the supply had been at 40V with no load, the output shot up to 58V when you drew current. And here, unfortunately, the overvoltage crowbar also proved to be inoperative. I suspect circuits inside the supply could have been fried; at one point my DC electronic load briefly claimed to be sinking 420 watts, but I must have caught it in time as it seems to be OK.
Scope quickly revealed that the power supply was in fact going unstable and screaming like a banshee, with chaotic 30Vpp power oscillations at 20-50kHz.
Time to confront the schematic. Fortunately Chris Grossman posted this excellent
manual scan. Here is the diagram:
While legible, just try and follow it; it's unintelligible! I'm 99% sure it was deliberately obfuscated, nobody could make such a mess without trying. They did label the controls, wires and test points, and even included test voltages, a step up from earlier PD schematics; so it seems they're letting you test individual components, but unwilling to reveal what they do or how.
I think someone on this forum quoted Bob Pease as saying nobody could understand a PD schematic unless they first redrew it; I have to agree. The very similar (and much earlier) 3650 schematic isn’t great, but has a vaguely logical signal flow. This gave me some hints. Here’s my version of the 4050. Yes, I reverse-engineered a schematic, from the OEM’s schematic (corrections appreciated).
First hint of progress was finding C12 was dried out, only showing 100 uF (diagram says 680 uF, but my unit came with 750 uF as-built). This is a shunt cap directly across the supply output. Adding 1,000 uF in parallel greatly diminished the oscillations, but did not eliminate them; the frequency moved up to several hundred kHz. I'd normally expect adding reactance would further destabilize a loop with poor phase margin, so I don’t really understand this yet.
Anyway at this point I noticed there’s actually a pot, R39, labeled “OSCILLATION SUPPRESSOR”. Someone had a sense of humor. Indeed, twiddling it fixed the oscillation, although the action seemed irregular and unrepeatable. Eventually I found the best setting was about where it started (marked at the factory with paint). My best guess is that R39 had corroded and the wiper went open, defeating a key lead/lag compensation network. Twiddling may have reestablished contact. (BTW in many places, as here, PD left open the unused ends of pots used as variable resistors, rather than shorting them to the wiper; this strikes me as a bad practice.)
So now the supply regulates well 0-40 volts, and quite easily puts out the rated current. Indeed, quite a bit more, if you ask; unfortunately, the current control is now completely inoperative. As is the overcurrent fault circuit. I’m afraid a lot of stuff may have gotten fried.
I will have to dig into those, and the useless crowbar, next. At least I can say the bias supply, reference, voltage regulator, and output pass bank are still good.
Taking a break, if anyone has any ideas or suggestions I’m keen to hear. I will attach some internal photos below to entertain the curious.
Cheers,
Z
