i HAVE A POWER SUPPLY WITH 5 WIRES THAT NEED TO BE SOLDERED TO THE BOARD. THE WIRES COMING OUT ARE ONE YELLOW WHICH I KNOW IS GROUND. TWO GREEN WIRES THAT HAVE 19 VOLTS ON EACH ONE AND 2 RED WIRES WITH ABOUT 40 VOLTS ON EACH ONE. I DO KNOW THE FIRST HOLE ON THE LEFT OF THE BOARD IS GROUND. wHERE DO THE RED AND GREEN WIRES GO. i HAVE ENCLOSED A SCHEMATIC OF THE BOARD.
