Were you able to get your drive cloned?
Yes! I did it!
I have tried a few cloning methods: PartitionSaving, CloneZilla Live. None of them were able to restore the disk.
Eventually I tried Ubuntu (Live 16.04 on a USB stick) and the 'dd' method worked, output file on another USB stick.
sudo dd if=/dev/sda > image_prema
Then, with the CF adapter and a 2GB CF card, on the IDE interface of my motherboard:
sudo dd of=/dev/sdf < image_prema
Final result (very professional mounting
Thanks to all for you help!
Michel.
