Author Topic: Problems with my scope (Charlie) Tektronix 2225 vertical amplifier.  (Read 14774 times)
Offline The GuyTopic starter
Re: Problems with my scope Tektronix 2225 vertical amplifier.
« Reply #25 on: September 22, 2017, 09:28:45 pm »
changing the DMM negative probe to either the emitter or the collector all combinations read zero.
Are you saying they are shorted?   :D
I guess not... there is infinite resistance the other way around ;)
Offline Armadillo
« Reply #26 on: September 22, 2017, 09:37:05 pm »
Can you insert the transistors back, then measure the voltages around Q102, Q103, Q104 and Q105?
« Reply #27 on: September 22, 2017, 11:21:51 pm »
Sorry had to go to the supermarket  :phew:
ok... installed them back and the voltages are:
Q102
Base: 4.37V
Emitter: 5.1V
Collector: -3.1V
Q103
Base: 4.37V
Emitter: 4.8V
Collector: -7.8
Q104
Base: -3.1V
Emitter: -3.78V
Collector: -0.3V
Q105
Base: -7.85V
Emitter: -8.56V
Collector: -0.3V
« Reply #28 on: September 23, 2017, 01:50:29 am »
Well, damn... I just discovered that the problem actually comes from the vertical attenuator preamp!!
It´s caos voltage-wise. Check schematic attached with recommended voltages and actual voltages in red.
If i jumper CH1+ with CH1- right after U30 the trace appears on the screen! I replaced U30 just in case and nothing changed.
I´m thinking maybe Q13 is screwed? Whatcha think?
« Last Edit: September 23, 2017, 01:55:55 am by The Guy »
« Reply #29 on: September 23, 2017, 02:30:09 am »
Sorry.... two voltages were swapped in the schematic above. Here they are corrected.
Re: Problems with my scope (Charlie) Tektronix 2225 vertical amplifier.
« Reply #30 on: September 23, 2017, 03:20:40 am »
Don't go pondering why the voltages you measure and those on the schematic don't agree.....Schematic DC voltages are only valid when the scope is set in a specified mode. RTFM.  ;)
Place it in XY mode and as the SM spec's and start at the V plates to check for balance and go from there...either backward or from the inputs. DMM is all you need to start with, use of another scope is later on if the DC voltages can't agree with the schematic in XY mode.
« Reply #31 on: September 23, 2017, 03:43:17 am »
Thanks, will do.
I measured another 222five and the voltages were very near the values per the schematics. Both scopes were set up the same.
What worries me is those 2.6V instead of zero right below R14. That´s very suspicious... I say something´s wrong right there.... How would you explain that voltage otherwise?
Thank you!  :-+
« Last Edit: September 23, 2017, 03:57:05 am by The Guy »
« Reply #32 on: September 23, 2017, 03:55:23 am »
In XY mode the trace is completely deflected to the right side. It only appears on the screen if I push the beam find button.
Offline Armadillo
« Reply #33 on: September 23, 2017, 03:56:32 am »
Alright Continued jumpering downstream. Jumpered at the base of Q104 and Q105 and the trace centered (almost)
then jumpered at the emitters from Q102 and Q103 and nothing happened.
So what happened that you did for Q102 and Q103? Need to uncover something, otherwise might just miss something important. Can we say dirty contacts? or measurement error?
Offline Armadillo
« Reply #34 on: September 23, 2017, 04:05:10 am »
C8 looks suspicious. Then adjust R33 to try bring the Pin 7 and Pin 13 equal.
Offline Armadillo
« Reply #35 on: September 23, 2017, 04:08:40 am »
If you like it on the right side to solve the vertical problem.
« Reply #36 on: September 23, 2017, 04:14:47 am »
...this is so weird... if I place a jumper before R100 and R101 the trace appears BUT if I jumper AFTER R100 and R101 (between R100-R101 and Q102-Q103) nothing happens.
Offline Armadillo
« Reply #37 on: September 23, 2017, 04:31:17 am »
Let just move forward to C8 and R33 as suggested above.      :)
« Reply #38 on: September 23, 2017, 04:37:09 am »
Nope... R33 doesn´t change a thing. Hmmmm.... this doesn´t smell good.
Offline Armadillo
« Reply #39 on: September 23, 2017, 04:42:20 am »
Is the C8 OK ? When you adjust R33, did the wiper voltage changed? Are you able to adjust it to 0 volt?
Edit: Check R22, R23, R29. With R22 powered to minus, you can adjust to negative voltage if you want.
« Last Edit: September 23, 2017, 04:46:39 am by Armadillo »
« Reply #40 on: September 23, 2017, 04:47:46 am »
With R33 maxed i get 8,7V before R32. 4.38V after R22 and 0.091V after R30!!! Is R30 Broken?
Offline Armadillo
« Reply #41 on: September 23, 2017, 04:52:49 am »
Lucky if the resistor is broken.   ;D otherwise U30 internal shorted but not common.
Let us know the good news.   ;D
Edit: Check C31!
Edit: otherwise change CA3102E.
« Last Edit: September 23, 2017, 04:56:46 am by Armadillo »
« Reply #42 on: September 23, 2017, 04:54:59 am »
C8 measures 83nF in circuit and 101Kohm resistance so I guess it´s not shorted.
Offline Armadillo
« Reply #43 on: September 23, 2017, 04:57:42 am »
Take it out of the circuit and changed it. It became a Resistor.
It should be 1000uF.
Edit: if defective out of circuit, then also change C31, might as well. Visual any leak onto the board. This area is crucial, it at the mouth of the amplifier. Wash and Scrup, Scrup, Scrup it if sign of leak. Put meter to 2M ohm range and touch the pcb board at non conductive part of that area, it should be infinity ohm.
« Last Edit: September 23, 2017, 05:06:05 am by Armadillo »
« Reply #44 on: September 23, 2017, 05:02:01 am »
Edit: Check C31!
Holy sh*t!!! C31/R31 junction to chassis measures 0ohm!! but to its lead that is supposed to be connected to ground it measures 98ohms
Offline Armadillo
« Reply #45 on: September 23, 2017, 05:04:06 am »
Edit: Check C31!
Resolve C8, C31, R31.
Offline Armadillo
« Reply #46 on: September 23, 2017, 05:08:50 am »
« Reply #47 on: September 23, 2017, 05:10:06 am »
Will do... but tomorrow. It is super late here...   :=\
What about those 2.6V right below R14? How do you explain that?
Offline Armadillo
« Reply #48 on: September 23, 2017, 05:11:37 am »
Because C8 became a Resistor.
Edit: I was watching the Dawn of the Dead just now, so I should say..... C8 became a Zombie.... LOL .
« Last Edit: September 23, 2017, 05:15:01 am by Armadillo »
« Reply #49 on: September 23, 2017, 05:34:16 am »
That'll stuff that whole area up.
Better change the one on the other channel too.
