Next up, I've had the supply on for a while, and the power transistors were getting quite toasty. There's clearly more significantly than 1A of current going through. So where's our current going? The output voltage is negative, so it must be coming from the negative rail. The only devices connecting to the negative rail are the output pre-driver transistor(Q110) and the four PNP power transistors (Q105-108).
The emitters of the power transistors are pulled out from under the heatsink in convenient test points. With the emitter voltages and output voltage known, it's trivial to calculate the currents through the emitter resistors. Let's make a diagram.
AHA!
Looks like something is pulling the output hard towards the negative rail. We're expecting about 1.2A current from the output, which is very close to the -1A the display is showing. That current is coming from ground, through the current shunt resistor and the flyback diode, D101. At this point, I suspected it would be one of three issues:
- Ouptut transistor failed
- Q110 failed
- Control circuitry failed
