I have question about CH341B programmer (3.3V from production).
Is possible with this programmer read (later maybe write) EN25Q40 SPI memory without soldering chip out from PCB?
PCB is Samsung TV board bn91-21809k made by Hansol.
I tested it when PCB was without power. I use Neoprogrammer software, installed WUDF driver, programmer was recognized by PC as USB-EPP IC CH341A. All seems OK also Neoprogrammer software recognize programmer, but when I connect adapter to EN25Q40 then PC and also Neoprogrammer software lost CH341B programmer connection. Supply voltage on EN25Q40 when CH341B was connected, was 3.2 V.
I forgot to add that I am 99% sure programmer was correctly connected to chip, both ends where double checked.
