This is what I was thinking as well that the memory chips might have gone bad as the ram vrm was shorted but after taking the mosfet out, I was able to see that they are fine and only the pads are shorted. Thus if I try to take out the inductor from that rail, it will tell me if the short is on the ram chips or at the driver part, right?
Also, I don't have a psu with curent limiting but I have some step up and step down convertor one of which actually has a curent limiting setup. Can I use that one whit a pc psu and insert 2v at 3A?
And yes, after removing the inductor on the aux vrm, from ground there was a voltage of 0.22~0.10. Also I removed one inductor fro the core vrm and as well the voltage raised from 0v to 0.22v
