Hey guys, I have a Rigol DS2072 oscilloscope that had something fall on it and broke off the horizontal position adjustment knob. The large two-part selection knob on the top right was also cracked. It's not the plastic knob that is damaged, the metal stem of the switch is broken right off.
Does anyone know of any sources for replacement switches that I can solder in? I did a search for the rotary switches for that oscilloscope but came up with nothing. I'm sure I'm just not using the correct keywords but I can't think of what else to try.
Also, is the rotary switch for the trigger adjustment or vertical position adjustments the same as the horizontal position switch? If they are, worst case I can swap the switches around so that it is at least still usable. However, I would much prefer to replace all the damaged switches.
Any suggestions are appreciated.
