Author Topic: Rohde & Schwarz Signal Gerator SML-01, (FIXED)  (Read 20547 times)
Offline IconicPCB
Re: Rohde & Schwarz Signal Gerator SML-01, (FIXED)
« Reply #25 on: April 09, 2019, 10:54:12 pm »
I have listed the procedure i had followed.
Note the belated instruction to "...read this page first..."
I cant comment on Your sig genny.
I would imagine being in the same vein as mine the firmware structure ought to be similar.
In any case do check the the screen for auto cal before changing the battery so that You are at least familiar with the user interface.
On issue of upgrading firmware....
Is there a compelling reason to upgrade or is it just going from functioninig version to one whihc may be marginally different?
Offline BravoV
  • +++ ATH1
« Reply #26 on: April 12, 2019, 06:59:17 am »
Noted, thanks.  :-+
Offline volvo_nut_v70
« Reply #27 on: July 20, 2019, 01:58:01 am »
Service manual with schematics Marconi/IFR/Aeroflex/R&S 2023 2024 2025 posted to BAMA and KO4bb
Offline Spirex
  • Country: ru
« Reply #28 on: October 23, 2019, 04:20:54 pm »
Hello!
Who knows the passwords for levels 3 and 4?
« Last Edit: October 23, 2019, 04:24:18 pm by Spirex »
Offline Spirex
  • Country: ru
« Reply #29 on: October 24, 2019, 12:02:31 am »
By breaking the dump, I calculated the passwords for the third and fourth levels.
LEVEL 1 Password: 123456
LEVEL 2 Password: 261339
LEVEL 3 Password: 710845
LEVEL 4 Password: 593748
The following users thanked this post: BravoV, Mark S
Offline BravoV
  • +++ ATH1
« Reply #30 on: October 24, 2019, 01:51:10 am »
Thank you.  :-+
Offline Mark S
  • Country: scotland
« Reply #31 on: November 04, 2019, 12:23:51 pm »
L3 - 4 passwords great .... I had the first 2 ae a bonus...
I am on the search for the Holy Grail or is it the hens teeth? Any one have a copy of the SML-Z2 software or know where I can procure a copy?
Regards
Mark=
Offline HighVoltageTopic starter
« Reply #32 on: November 05, 2019, 05:12:07 pm »
Regards
Mark=
I tried to find this but was not successful !
Offline 1498ts
  • Country: tw
« Reply #33 on: November 11, 2020, 12:46:57 pm »
Hi !
Is Anyone can have the password for level 2 & level 3  ?
Offline mankan
« Reply #34 on: November 11, 2020, 05:20:48 pm »
I found the SMP passwords at https://groups.io/g/Rohde-and-Schwarz , maybe they are the same.
LEVEL1: 123456
LEVEL2: 520805
LEVEL3  490727
Also unlocking thru GPIB, according to what I've found unlocks all levels.
Offline vberk
« Reply #35 on: August 27, 2021, 09:41:31 am »
Hello to everyone!
I have the SML01 that does not respond to keyboard but responds to the rotary knob. The keyboard matrix is working as I see it transmits pulses to PERIF2 chip.  I suppose it is a problem with flash firmware.
I see no way to update firmware through RS-232 as there is need to press key "5" before update process but there is no response to keypress.
Does anyone have the flash dumps from SML-01-02-03 or SMV-03?
I would appreciate for help.
Offline Spirex
  • Country: ru
« Reply #36 on: August 27, 2021, 10:02:09 am »
SML-01 Dump firmware for programmer chip. Archive password  12345
https://drive.google.com/file/d/1-EHZLpTz7vT7UJbwZslaBt0m7b7XmC5k/view?usp=sharing
EEPROM 24645
AM29LV160DT 1
AM29LV160DT 2
The following users thanked this post: BravoV, vberk
Offline vberk
« Reply #37 on: August 27, 2021, 10:35:54 am »
Hi, Spirex!
Thanks a lot for dumps!
What programmer did You use for that?
Were there nuances with reading/writing the chips?
Is 24645 also from this SML-01?
Offline Spirex
  • Country: ru
« Reply #38 on: August 27, 2021, 10:41:29 am »
Hi!
Programmer TL866A with programming panels tsop-48.
There were no programming problems.
I just do not remember where installed on the board EEPROM X24645P
If the keyboard does not work, I think you need to enter the programming mode through the digital interface on the back of the generator using the control commands described in the service manual.
« Last Edit: August 27, 2021, 10:52:13 am by Spirex »
The following users thanked this post: vberk
Offline vberk
« Reply #39 on: August 27, 2021, 01:29:24 pm »
Ok. I was thinking about it to enter the programming mode through the GPIB. But have not GPIB adpter yet.
Thanks.
Offline charlyd
« Reply #40 on: January 31, 2022, 11:35:18 am »
Great SML topic this is.
I am looking for the SML-Z2 utilty (1090.5203.02) for calibrating my SML generator.
Does anyone have this utility and is willing to share it here?
is there already a sort of "standard walkthrough" path for a not booting units related/refers to display problems?
« Last Edit: January 31, 2022, 12:05:37 pm by charlyd »
Offline EEngo
« Reply #41 on: September 02, 2023, 10:45:32 am »
does someone know where to find the firmware and/or the update utility? My SML has an EEPROM checksum failure, I'd like to fix that  :box:
Thanks!
Offline Martin72
  • Testfield Technician
« Reply #42 on: December 11, 2023, 09:29:59 pm »
Hi... ;)
A few days ago I used the sweep function of my SML01 for the first time, from 1Mhz to 1Ghz.
I noticed that between 1Mhz and just over 5Mhz the set 0dBm level is higher, after that it is exactly the same.
Is this a calibration problem or a defect or is it normal?
Offline Spirex
  • Country: ru
« Reply #43 on: December 12, 2023, 08:58:55 am »
At some sweep switching time, this effect exists.
Offline Spirex
  • Country: ru
« Reply #44 on: April 08, 2024, 05:21:55 pm »
I'll duplicate the link. The archive contains dumps from microcircuits, and software from the manufacturer for programming the generator.
https://drive.google.com/file/d/1En2RaBFdwcJvHx7VV3AnrDAZthTMBvy8/view?usp=sharing
