SilverSolder is right, stuff happens.
Most of the IC amps today are pretty bombproof.
Even a short to ground doesn't annoy them too much.
When removing multiple pin devices, I always like to destroy them.
I cut the leads off as near the body as I can.
Sometimes I even use a Dremel tool.
Then I can unsolder the leads individually.
This saves wear and tear on the PCB.
You can look at the headphone driver now if you like.
The obvious thing would be if the op amps were missing one leg of power.
They could be blown too.
If somebody had plugged a cable from ext speaker out to headphones out....
Yes I tend to cut off legs on faulty components too. I usually dob them with some red paint as well, I have a box of broken electronic bits that might make some good artwork one day haha.
Moving on...
Is it safe to run the amp without the IC to fault find further? Or shall I replace it first?
As for the op amps, they are all on the 12/-12V regulated rail. Do you think they could be affected? I guess I could test for direct shorts on them. What say you?
What about the speaker. It still measures 8 ohms on the DMM
but could it be damaged? It doesn't push in and out very much but i can't feel the coil rubbing either.
And headphone circuit. What to test first?
The last few DIY repairs I have done all tend to be shorted silicon components. Are modern silicon components just rubbish or something?
