Author Topic: [SOLVED]R&S cmu200 HDD image file wanted.  (Read 4242 times)
Offline eurgencaTopic starter
  • Country: si
« on: October 21, 2021, 02:22:57 pm »
Hello. I have cmu200 with corrupted HDD drive. It is full of bad sectors. At startup I get error message on picture. Can someone upload disk image or point me where to find instalation files for fresh install. I made a copy of disk and save 97% of files.
Sebastijan.
« Last Edit: November 13, 2021, 02:44:28 pm by eurgenca »
Offline ve7xen
    • VE7XEN Blog
Re: R&S cmu200 HDD image file wanted.
« Reply #1 on: October 21, 2021, 07:51:25 pm »
I have some files (the installers) at http://gotroot.ca/cmu200/ . If you can put them on a PCMCIA/CF card and boot into the built-in upgrader and install them, you should be able to restore all the applications this way, I think. I don't have an easy way to get a disk image for you at the moment.
73 de VE7XEN
He/Him
The following users thanked this post: eurgenca
Offline fzabkar
« Reply #2 on: October 21, 2021, 11:27:57 pm »
Can you upload your files so that we can compare them against the files in the installers? Perhaps the solution is to repair the damaged files, preferably on a clone HDD.
The following users thanked this post: Bravo
  • Country: si
« Reply #3 on: October 23, 2021, 10:01:10 am »
Hello.
I uploaded files that I can manage to copy from HDD.
When I got this cmu system halt's on rohde & schwarz welcome screen. When I clone HDD and repair it with scandisc I came to error on picture. I don't know if this is SW or HW error. So idea is to copy image file if somebody will share with me.
I ordered PCMCIA to CF adapter for upgrade, but it will arrive in next week.
My files:
https://www.mediafire.com/file/6hfzl76u0tstoia/Cmu_back.rar/file
P.S. Anyone know why model and serial number is not listed? Or it comes later in boot sequence?
« Last Edit: October 23, 2021, 10:07:47 am by eurgenca »
Offline fzabkar
« Reply #4 on: October 23, 2021, 06:23:38 pm »
How did you clone the drive? Ideally you would use a tool such as ddrescue or HDDSuperClone. These tools keep a log of unreadable sectors, and you can then use this log to determine which files were affected. Alternatively you could fill each bad sector with a test pattern (eg BAD!BAD!...) and then search for this pattern in your recovered files.
Online samofab
  • Country: si
« Reply #5 on: October 23, 2021, 08:27:01 pm »
I have CRTU and when I got it I made a copy of the disk using clonezilla. And I have the same flag as OP. PM me if you think CRTU image helps. AFAIK DOS software is the same for CMU200 and CRTU.
« Last Edit: October 23, 2021, 08:32:14 pm by samofab »
  • Country: si
« Reply #6 on: October 23, 2021, 09:10:25 pm »
 have made clone with hddrawcopy SW. Cmu now boot every time same and stops (not hang) on stuc file. I was check connection of flat cable and looks fine.
Offline fzabkar
« Reply #7 on: October 23, 2021, 09:44:07 pm »
AFAICT, stuc.cpp is a C++ source file. It does not exist in your file dump, but it is referenced in file "CMU\BIN_V5.00\BASE\FSW\1\CMUDRV.DL0".
  • Country: si
« Reply #8 on: October 23, 2021, 10:00:56 pm »
I think that "BaseDiscoverOptionsBegin" mean that system checking installed HW. But in my case I don't get serial and model number. So where is this data stored?
"feldent" = NULL this in german mean "field".
I have ni idea with c++ can you tell me what this stuc file is lookin for.
  • Country: si
« Reply #9 on: October 23, 2021, 10:09:07 pm »
Ha. :o
I open this file with notepad and is full of crap. Is it better way to open this CMUDRV.DL0 file.
Offline fzabkar
« Reply #10 on: October 23, 2021, 10:14:58 pm »
Open it with a hex editor, eg HxD (freeware).
https://mh-nexus.de/en/hxd/
Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
001ED410  3D 20 4E 55 4C 4C 00 2E 2E 5C 2E 2E 5C 73 72 63  = NULL...\..\src
001ED420  5C 73 74 75 63 2E 63 70 70 00 46 65 49 64 65 6E  \stuc.cpp.FeIden
001ED430  74 20 21 3D 20 4E 55 4C 4C 00 2E 2E 5C 2E 2E 5C  t != NULL...\..\
« Last Edit: October 23, 2021, 10:18:35 pm by fzabkar »
  • Country: si
« Reply #11 on: October 23, 2021, 10:15:30 pm »
This may be interested
src\stuc.cpp stu_call_write_serial_number() this pointer corrupted %lu[ms] stu_call_write_serial_number(
src\stuc.cpp DigIdent != NULL ..\..\src\stuc.cpp RefIdent != NULL ..\..\src\stuc.cpp FeIdent != NULL ..\..\src\stuc.cpp stu_call_write_serial_number
« Last Edit: October 23, 2021, 10:17:46 pm by eurgenca »
  • Country: si
« Reply #12 on: October 23, 2021, 10:22:04 pm »
So it looks like it is related with SN. But where is this data stored? Fmr, DIG module some other module...
Offline fzabkar
« Reply #13 on: October 23, 2021, 10:31:10 pm »
Have you executed the self test? ISTM that the boot process involves the identification of each of the installed PCBs/modules. AFAICT, each module has an EEPROM. Maybe the EEPROM on the RF Frontend has a problem???
http://cdn.rohde-schwarz.com/pws/dl_downloads/dl_common_library/dl_news_from_rs/167/167_CMU200selftest.pdf
FE Selftest
RF FRONTEND.
Output of defined supply voltages and logic switching voltages, limit values and current measured value for each voltage.
REF Selftest
REFERENCE BOARD.
Output of defined tuning and amplitude voltages of PLLs at different frequencies, output of supply voltages and module temperature, limit values and current measured value for each voltage.
DIG Selftest
DIGITAL BOARD.
Output of defined supply voltages and frequency-proportional voltages of clock signals, limit values and current measured value for each voltage.
« Last Edit: October 23, 2021, 10:36:38 pm by fzabkar »
  • Country: si
« Reply #14 on: October 23, 2021, 10:40:58 pm »
I think that this stuc file create a log file in "stuc.cpp C:\INTERNAL\LOG\TOOLS \*.Y00". But files are date related. So I must correct date in bios and reboot cmu. Anyway I am going to sleep. Cmu must wait.
No I did not do this test, Only acesseble sw is version installer.
Offline fzabkar
« Reply #15 on: October 23, 2021, 10:58:13 pm »
I expect that the problem is in this module:
https://www.ebay.com/itm/324475394824
Offline fzabkar
« Reply #16 on: October 23, 2021, 11:14:09 pm »
FE Ident -> Front End Identification
  • Country: si
« Reply #17 on: October 24, 2021, 07:19:05 am »
Fzabkar you are the man.
I was so frustrated with bad sectors on HDD, that didn't think out of the box. Now I remember that fan on this module is not spinning... I thought that is maybe temp. controlled.
  • Country: si
« Reply #18 on: October 24, 2021, 07:22:17 am »
Definitely will be the first thing that I will pulled out and look inside. I hope is some power related problem.
  • Country: si
« Reply #19 on: October 24, 2021, 04:32:58 pm »
Oh god what I bought.  :palm:
First I want to check connection between frontend and MB. WTF, where is flat cable? |O
 O.k. I found suitable cable and restore connection. Power up cmu and booting pass through stuc error. Serial and model number is showing.
YES and then
1306181-0
and
1306187-1
O.k. I boot to version manager and select options:
-clear nvram
-flash when board is changed
Same errors.
Then I was again boot to version manager and install older SW.
It looks o.k. Booting finish and all looks good.
After that I again change SW version to 5.00 and same errors appear. So What is this "overlay.c" related.
Ok, I was again downgrade version to 4.0 and looks all o.k.
I run self tests and all pass exept RF loop. (internal and external).
It is look like RF1 and RF2 ports are busted. But let this for later.
What do you think is to do. Try to upgrade to latest ver. or I leave 4.0.
Offline fzabkar
« Reply #20 on: October 24, 2021, 06:16:53 pm »
It doesn't help me, but I found this in BIN_V5.00\BASE\BSW\EXE\BASE.EXE:
00592BC0  2E 5C 2E 2E 5C 2E 2E 5C 6F 73 2E 30 33 31 5C 63  .\..\..\os.031\c
00592BD0  5F 73 6F 75 72 63 65 5C 6F 76 65 72 6C 61 79 2E  _source\overlay.
00592BE0  63 00 4F 76 65 72 6C 61 79 20 2D 20 49 6E 69 74  c.Overlay - Init
00592BF0  00 4F 76 65 72 6C 61 79 20 2D 20 49 6E 73 74 61  .Overlay - Insta
00592C00  6C 6C 00 4F 76 65 72 6C 61 79 20 2D 20 52 65 6D  ll.Overlay - Rem
00592C10  6F 76 65 00 4F 76 65 72 6C 61 79 20 2D 20 4C 6F  ove.Overlay - Lo
00592C20  61 64 44 6C 6C 00 5C 00 4F 75 74 20 6F 66 20 76  adDll.\.Out of v
00592C30  69 72 74 75 61 6C 20 6D 65 6D 6F 72 79 2E 20 20  irtual memory.
... and I see the same thing in BIN_V4.10\BASE\BSW\EXE\BASE.EXE.
005881C0  2E 2E 5C 2E 2E 5C 2E 2E 5C 2E 2E 5C 6F 73 2E 30  ..\..\..\..\os.0
005881D0  33 31 5C 63 5F 73 6F 75 72 63 65 5C 6F 76 65 72  31\c_source\over
005881E0  6C 61 79 2E 63 00 4F 76 65 72 6C 61 79 20 2D 20  lay.c.Overlay -
005881F0  49 6E 69 74 00 4F 76 65 72 6C 61 79 20 2D 20 49  Init.Overlay - I
00588200  6E 73 74 61 6C 6C 00 4F 76 65 72 6C 61 79 20 2D  nstall.Overlay -
00588210  20 52 65 6D 6F 76 65 00 4F 76 65 72 6C 61 79 20   Remove.Overlay
00588220  2D 20 4C 6F 61 64 44 6C 6C 00 5C 00 4F 75 74 20  - LoadDll.\.Out
00588230  6F 66 20 76 69 72 74 75 61 6C 20 6D 65 6D 6F 72  of virtual memor
00588240  79 2E 20 20 20 20 20 20 20 20 20 20 20 20 20 20  y.
According to the service manual, there is a "Lithium battery in FRONT MODULE". I expect that this would provide power for the non-volatile RAM.
"GE 3.0V 230MAH LI-MNO2 LITHIUM BATTERY CR2032"
"EB 3.6V 1.00AH LI-SOCL2 LITHIUM THIONYL CHLORIDE BATTERY"
Edit:
ISTM that the CMU200 is unable to load one if its DLL files. To this end I have listed all the DLLs for the two firmware versions.
Do you have a log file for your Clonezilla session?
« Last Edit: October 24, 2021, 07:34:41 pm by fzabkar »
  • Country: si
« Reply #21 on: October 24, 2021, 08:23:21 pm »
Hi.
No I don't have a log file, but I have original HDD and I have one IDE SSD disk (8Gb). I can try to make clone with Clonezilla to this disk.
Your plan is to see on which file bad sectors are affected. Am I wright? :-//
Offline fzabkar
« Reply #22 on: October 24, 2021, 08:34:25 pm »
I confess that I'm only guessing as to the real cause of your problems.
I would suggest that HDDSuperClone is a better tool than Clonezilla. It can save a log file and fill bad sectors with a chosen pattern. It has a LiveCD and a GUI.
In any case, if the problem is a version 5.0 DLL file, then I would expect that a firmware update should fix this. ICBW, though.
  • Country: si
« Reply #23 on: October 24, 2021, 08:54:04 pm »
What does "out of virtual memory"mean.
That LoadDll cannot be loaded because is corrupted or really not enough memory. If I remember correct in DOS for virtual (extended) memory was himem.sys
I will check autoexec.bat and config.sys under both versions.
Offline fzabkar
« Reply #24 on: October 24, 2021, 09:39:00 pm »
When I think of virtual memory, I think of swap space on a hard drive.
DOS used extended or expanded memory to access memory above the 1MB limit. Himem.sys was able to access the first 64KB memory segment above 1MB, IIRC.
