The metal grille will be held in with hot melt glue or other sticky substance. Warm the entire speaker in direct sunlight then unfold 3 or 4 paperclips into a shape that can be looped through the grill in each corner. You can also use a pick-type tool. If the glue is soft, it won't take much pulling, but be persistent. The grill will come out eventually.
