Hi;
Firstly Diode Check D801 and D19. Are they OK?
If Yes;
Turn On the TV and measure the voltage at cathode of D801 with respect to Pin 10 of IC1 [gnd].
Is the voltage > 3.5v?
If yes;
Then measure the voltage at the cathode of D19 with respect to Pin 10 of IC1 [gnd].
If yes;
Then measure VC_S_F with respect to Pin 10 [gnd] of IC1 [see attached]
Is voltage > 15 V?
If Yes;
Turn Off TV
Set meter to Diode mode, Check PC1S, measure across Pin 4 and Pin 3 for shorts.
Is the measurement OK?
Double confirm C13 that the newly installed Cap is OK, measure ESR, confirm +ve lead is to Pin 5 of IC1.
If YES, then you will have to replace IC1. $1.30 from China. We went through a lot of troublesome steps to confirm this.
Please post results.
Edit:
If No VC_S_F;
Measure the voltages shown in attached and post results.
